Home > Td5 > New nocking sound after diff oil change
Kozzy
United Kingdom 2001 Defender 110 2.5 TD CSW Caledonian Blue
Hi everyone,
I have a 2001 110 td5 with a salisbury rear diff.
Went for a drive all was good, parked on the main road that is level, to change the oil in the diff.
I have a pump like this one below.
https://www.amazon.co.uk/Draper-01082-Purp...mp;sr=8-21
Undone the fill / level bung plastic oil was pouring out.
Undone the drain plug( metal with magnet, no metal on it ) and waited until it was all empty.
Showed the hose of the pump in the oil bottle and the other side in the fill hole.
Filled it up until it was coming out.
Got in to drive it and i have this knocking noise now.
https://youtube.com/shorts/F-i4M8rtsyU?feature=share
This is how it sounds while both wheels are in the air
https://youtube.com/shorts/5C7wDfZMzLw?feature=share
The oil is 80W90, and it took about 2L.
Anyone can shed some idea on what to look at? Could have i dislodged something with the hose? Its a slightly plastic hose, not a full rubber one.
Thanks
Post #1008770 25th Sep 2023 8:36am
excossack
Could the filler plug be wound in too far?
or something come off the end of the hose?
 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1008777 25th Sep 2023 9:11am
Dinnu
As excossack. If you tighten to much you can even drop it inside. It only needs nipping up.
You may use a bit of ptfe tape if you think it may leak. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1008778 25th Sep 2023 9:25am
Kozzy
hi,
could be it, the bloody thing just goes and goes.
I will try this tonight
Post #1008779 25th Sep 2023 9:26am
excossack
Does strike me as being odd, having no flange to stop bung being wound in too far 1999 Defender TD5 110
Regards
John M0VAZ
Post #1008780 25th Sep 2023 9:33am
Kozzy
now reading online i think the drain plug is proper tight, as i found it somewhat tight and i have done it up tighter lol Got da 110 TD5 2001 Smile
Post #1008782 25th Sep 2023 9:43am
TexasRover
It's pipe thread which is tapered so it jams in. You do not want to overtighten it. No point.
There are more sophisticated plug designs, but this works perfectly fine and is simple with no gaskets required
Post #1008783 25th Sep 2023 9:44am
Kozzy
Yes, now it is evident that I have tightened them to oblivion. Got da 110 TD5 2001 Smile
Post #1008784 25th Sep 2023 9:57am
geobloke
Re: New nocking sound after diff oil change
Kozzy wrote:
Hi everyone,
Thanks
That oil looks like it has water contamination, very milky looking. Check your axle breather. It ends up under the offside rear wheel arch. It should have a looped over end to prevent water from being sucked into the axle, but the pipe can perish close to the chassis and sit there in the worst of the wheel arch spray and dirt.
The fact the even when jacked up the oil was pouring out suggests either the vehicle was pointing downhill when filled last time or the oil has become contaminated since then... Hence the above.
OK, your knocking noise sounds tinny with a constant frequent impact like sound. Like a playing card in the spokes of a bike wheel, but more rigid sounding.
Something is rubbing against the crown wheel perhaps. Have you lost something off the pump into the axle?
There are two ways to find out: the first is an endoscope through the bung hole and the second is to take the cover off the diff. Only sure ways to know. Benefit of the second is you can get eyes on the gears, check for chipped teeth, etc. but also the opportunity to flush and clean out the axle if it is contaminated.
If it were me I would take the Salisbury plate off and take a look.
Post #1008786 25th Sep 2023 10:02am
Kozzy
thanks for that.
The landy was not lifted for oil change, and it was on level ground.
A good 200 - 300ml has poured out while only the filler was removed.
The contamination part makes sense as it was more than 2L in it, it was a lot of fluid.
The hose from the pump was a fresh hose i cut nothing on the end to fall in.
The knocking noise does speed up as i go faster.
I will remove the cover and get a gasket and flush it.
Thanks Got da 110 TD5 2001 Smile
Post #1008790 25th Sep 2023 10:16am
geobloke
Best plan IMHO. Check that breather hose whilst you are under there.
Post #1008796 25th Sep 2023 10:43am
Kozzy
will do thanks Got da 110 TD5 2001 Smile
Post #1008800 25th Sep 2023 11:23am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Another diff noise
?si=a96tbYvH6jKUa6va&t=245
(at 4:00)
And its cause Shocked
?si=Ho9c-yzFuZZDaaLs&t=149
(at 2:30)
In the end Mike replaced the Puma's axle with a Salisbury one Cool
Post #1008840 25th Sep 2023 5:09pm
Kozzy
Sent it to bloody deep lads .... tooooo fffff deeep.
Whats next? Will it survive like this ? Got da 110 TD5 2001 Smile
Post #1009003 26th Sep 2023 4:50pm
Dinnu
As a minimum, drain the oil to remove as much metal shavings as possible,
Better still is to take off the diff pan, and clean manually.
Try to get a magnetic drain plug, if you do not already have one, so it picks up whatever you have missed.
Then fingers crossed. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1009015 26th Sep 2023 5:17pm
