![]() | Home > Td5 > New nocking sound after diff oil change |
Kozzy Member Since: 17 Jul 2023 Location: Milton Keynes Posts: 10 ![]() ![]() ![]() |
yeah only done about 200m on it like this at low speed.
Will clean it out and get a replacement cover as well just in case, this is nafff. What do you guys recommend flushing the diff out with ? And yes the drain plug is a magnet one, i was surprised it there were no shavings on it at all. Got da 110 TD5 2001 ![]() |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1645 ![]() ![]() |
brake cleaner or similar solvent is all you need.
if the plug doesn't leak when its wound in i wouldn't swap the pan. 200mtr at slow speed and minimal metal loss you should be ok |
