Home > Puma (Tdci) > Snorkel?
Shropshirelad
United Kingdom 2011 Defender 90 Puma 2.4 HT Zambezi Silver
Snorkel?
Which one is the easiest to fit? Done loads of 200 and 300tdis but not a Puma yet?
Post #1007039 9th Sep 2023 8:11pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I opted for a Mantec raised air intake, because I liked the classic look but this version is plastic so won't rust.
It used the existing screw holes in the wing, so no drilling necessary, except into the windscreen frame.
I didn't change anything under the bonnet, so I won't be going snorkelling in it!
It was an easy job to fit it.
Post #1007048 9th Sep 2023 9:33pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi
Sorry to hi jack your thread....
Does anyone know of a snorkel that mounts using 4 holes on the side (instead of the front) of the windscreen frame?
I have 4 holes fitted with screw grommets and my OCD is suffering!
Jim
Post #1007106 10th Sep 2023 12:49pm
camelman
The genuine safari snorkel mounts there
Post #1007109 10th Sep 2023 1:04pm
jim4244
Thanks Camelman Thumbs Up
I don't think that I have ever seen one but I bet that they aren't cheap!
Jim
Post #1007110 10th Sep 2023 1:26pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Just be sure you really want one, I wished the previous owner hadn't fitted one to mine as I want rid but will be left with loads of holes! 2004 Defender 90 Td5 CSW
2002 Discovery 2 td5 GS (gone)
1994 Defender 90 300Tdi CSW (gone)
Post #1007112 10th Sep 2023 1:38pm
TexasRover
Yeah also the po fitted what looks to be an original high air intake on my Td5 and it limits the wing of the RH (in my case passenger door) to it will no longer stay latched open as the mirror arm hits the snorkel.
I was looking at repositioning or shortening the arm so that it latches at a lesser angle.
Post #1007118 10th Sep 2023 3:33pm
macfrank
The Mantec was very easy to fit but no way I'm going to drill into that flimsy windscreen frame.
I fixed it to an aluminium square tube with brackets under the "hinge" block and the rain gutter.
Never had an issue even on very bad offroad tracks.
Post #1007138 10th Sep 2023 6:41pm
