Home > Puma (Tdci) > Snorkel? |
Shropshirelad Member Since: 28 Aug 2023 Location: Shresbury Posts: 20 |
Which one is the easiest to fit? Done loads of 200 and 300tdis but not a Puma yet?
9th Sep 2023 8:11pm |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 335 |
I opted for a Mantec raised air intake, because I liked the classic look but this version is plastic so won't rust.
It used the existing screw holes in the wing, so no drilling necessary, except into the windscreen frame. I didn't change anything under the bonnet, so I won't be going snorkelling in it! It was an easy job to fit it. Click image to enlarge |
9th Sep 2023 9:33pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3372 |
The genuine safari snorkel mounts there
10th Sep 2023 1:04pm |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 780 |
Thanks Camelman
I don't think that I have ever seen one but I bet that they aren't cheap! Jim |
10th Sep 2023 1:26pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 928 |
Just be sure you really want one, I wished the previous owner hadn't fitted one to mine as I want rid but will be left with loads of holes! 2004 Defender 90 Td5 CSW
2002 Discovery 2 td5 GS (gone) 1994 Defender 90 300Tdi CSW (gone) |
10th Sep 2023 1:38pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1051 |
Yeah also the po fitted what looks to be an original high air intake on my Td5 and it limits the wing of the RH (in my case passenger door) to it will no longer stay latched open as the mirror arm hits the snorkel.
I was looking at repositioning or shortening the arm so that it latches at a lesser angle. |
10th Sep 2023 3:33pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1076 |
The Mantec was very easy to fit but no way I'm going to drill into that flimsy windscreen frame.
I fixed it to an aluminium square tube with brackets under the "hinge" block and the rain gutter. Never had an issue even on very bad offroad tracks. Click image to enlarge Click image to enlarge Click image to enlarge |
10th Sep 2023 6:41pm |
