Home > Puma (Tdci) > It won't start |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
You have to code the 10 AS ecu to the car if replaced.
19th Aug 2023 4:37pm |
Vmax Member Since: 29 Apr 2023 Location: Europe Posts: 73 |
Sorry Sir can you specify on that code.
19th Aug 2023 4:52pm |
Is that needs to be recoded by the dealer. |
19th Aug 2023 4:57pm |
Did you replace the Green or Black module for the immobiliser?
The 10AS alarm has to be matched to the engine computer (PCM) for the immobiliser to work. |
19th Aug 2023 9:04pm |
No l haven't replaced that
19th Aug 2023 9:22pm |
Any codes present?
19th Aug 2023 9:45pm |
Sorry Sir no code l need to read about it.
19th Aug 2023 9:59pm |
Is the stamped on the metal a four code on the spare key set
19th Aug 2023 10:17pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17388 |
What did you actually replace? There's a word missing from your first post. |
19th Aug 2023 10:31pm |
True l missed a word. That l checked and changed fuses.
20th Aug 2023 6:51am |
Yesterday l removed the three immobiliser fuses so that the immobiliser would disconnect
So l had it more than twelve hours. Put the fuses back on late this morning it started perfect and the fobs l have two one of them is not working. |
20th Aug 2023 1:42pm |
With vehicle unlocked, take the battery out of fob and then hold both buttons down for 10 seconds to drain residual power.
Put the Battery back in then press lock four times and unlock once. That will sync the fob back to the ECU. |
20th Aug 2023 2:16pm |
I will am on it thank you.
20th Aug 2023 2:44pm |
Fob is working thank you very much.
Do l need to do a diagnostic on the immobiliser. Or l do some driving test for a few days to double check is going start. |
20th Aug 2023 8:29pm |
