![]() | Home > Puma (Tdci) > It won't start |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
You have to code the 10 AS ecu to the car if replaced.
Vmax Member Since: 29 Apr 2023 Location: Europe Posts: 76 ![]() ![]() ![]() |
Sorry Sir can you specify on that code.
Is that needs to be recoded by the dealer. |
Did you replace the Green or Black module for the immobiliser?
The 10AS alarm has to be matched to the engine computer (PCM) for the immobiliser to work. |
No l haven't replaced that
Any codes present?
Sorry Sir no code l need to read about it.
Is the stamped on the metal a four code on the spare key set
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17727 ![]() ![]() ![]() |
What did you actually replace? There's a word missing from your first post. |
True l missed a word. That l checked and changed fuses.
Yesterday l removed the three immobiliser fuses so that the immobiliser would disconnect
So l had it more than twelve hours. Put the fuses back on late this morning it started perfect and the fobs l have two one of them is not working. |
With vehicle unlocked, take the battery out of fob and then hold both buttons down for 10 seconds to drain residual power.
Put the Battery back in then press lock four times and unlock once. That will sync the fob back to the ECU. |
I will am on it thank you.
Fob is working thank you very much.
Do l need to do a diagnostic on the immobiliser. Or l do some driving test for a few days to double check is going start. |
