Home > General & Technical (L663) > Who makes the Elift kit? |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 788 |
https://newdefendermods.com/collections/su...t-drop-kit
Says it comes from Oz, anyone know who developed or made the kit? Thanks. |
11th Aug 2023 12:02pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2688 |
Is it not just the Llams system?
11th Aug 2023 5:05pm |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 434 |
For the Llams height controller contact Graeme Small in Australia.
kits@llams.com.au I did pay last year Aus $ 575,- including shipping. Excluding customs and VAT. Don't know his pricing at this time. Click image to enlarge No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
11th Aug 2023 7:24pm |
Nicofender Member Since: 16 Jan 2023 Location: Southern Posts: 51 |
What I don’t understand with all the LLAMS and rods, can you really lift the car higher than the LR extended mode? Is there a real lift to the stock system or is it just about control?
13th Aug 2023 3:41pm |
I see. Get it now. Thanks for the enlightenment
14th Aug 2023 8:28am |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 145 |
In theory you can use rods or the Llams to go all the way to the limits of suspension travel, so far beyond the OEM extended height. Both fool the EAS ECU into thinking the suspension is lower or higher at rest than stock, so the ECU adjusts to compensate. The rods do it mechanically with a shorter or longer link rod whereas the Llams is plugged in between the EAS ECU connector and the ECU itself, providing a flase reading electronically.
The IIDTool reprograms the base settings of the suspension to provide a lift (or lowering). You can save 3 different height settings for different situations. It's not as quick as the Llams which only requires a twist of a button (the IIDTool takes about 30-40 sec) but, in the case of a problem with the air suspension, the IIDTool will allow manual control of the air suspension - even with a so called "hard fault" where the car lowers itself to the bump stops for safety reasons. Ask us how this all came to be RRC 2Dr, RRC 4Dr, P38, and 2 L322s, 2 FL1s and a L663 on the way |
14th Aug 2023 10:14am |
