Home > General & Technical (L663) > Who makes the Elift kit?
Chicken Drumstick
https://newdefendermods.com/collections/su...t-drop-kit
Says it comes from Oz, anyone know who developed or made the kit? Thanks.
Post #1003763 11th Aug 2023 12:02pm
Retroanaconda
Is it not just the Llams system?
Post #1003789 11th Aug 2023 5:05pm
Defendit..
Netherlands
For the Llams height controller contact Graeme Small in Australia.
kits@llams.com.au
I did pay last year Aus $ 575,- including shipping. Excluding customs and VAT. Don't know his pricing at this time.
 No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1003802 11th Aug 2023 7:24pm
Nicofender
Germany
What I don’t understand with all the LLAMS and rods, can you really lift the car higher than the LR extended mode? Is there a real lift to the stock system or is it just about control?
Post #1003986 13th Aug 2023 3:41pm
Defendit..
Netherlands
Rods just raise the height on all the settings, cheap but not comfy.
Body lift gives you clearance with the stock suspension, expensive but perfect.
Llams gives you a lot of choices on every setting and speed.
For example you can drive on the autobahn setting low or parkhaus extra low.
In case you are getting ( or expected ) stucked offroad raise to super extended,
For daily driving on the low setting it is recommended to re-align your caster/camber. No Mud flaps for my 90.!
Post #1004046 14th Aug 2023 7:37am
Nicofender
Germany
I see. Get it now. Thanks for the enlightenment Thumbs Up
Post #1004047 14th Aug 2023 8:28am
stevemfr
France
In theory you can use rods or the Llams to go all the way to the limits of suspension travel, so far beyond the OEM extended height. Both fool the EAS ECU into thinking the suspension is lower or higher at rest than stock, so the ECU adjusts to compensate. The rods do it mechanically with a shorter or longer link rod whereas the Llams is plugged in between the EAS ECU connector and the ECU itself, providing a flase reading electronically.
The IIDTool reprograms the base settings of the suspension to provide a lift (or lowering). You can save 3 different height settings for different situations. It's not as quick as the Llams which only requires a twist of a button (the IIDTool takes about 30-40 sec) but, in the case of a problem with the air suspension, the IIDTool will allow manual control of the air suspension - even with a so called "hard fault" where the car lowers itself to the bump stops for safety reasons. Ask us how this all came to be Laughing
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #1004060 14th Aug 2023 10:14am
