Home > Technical > td5 abs
olistr
Germany
td5 abs
Hi guys,
qq.
On a td5 from 2002 with ABS, I understood how it works on the Back with the sensor and the ring.
On the front however, I only find references to the sensor, but what is the sensor reading from? I don't see any reference to a ring or anything like in the back.
Post #1003504 9th Aug 2023 5:57pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
The 'ring' is part of the the CV joint the sensor can be seen entering through the top of the swivel pin. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #1003507 9th Aug 2023 6:00pm
olistr
Germany
Hi does that mean there are abs specific cv joints? Couldn‘t find any reference on lrworkshop. Or is that „ring“ in all cv-joints?
Post #1003509 9th Aug 2023 6:09pm
rustandoil
I don't know the precise answer, but have a look here.... In the picture you can see the ABS notches
https://www.lrworkshop.com/parts/TDJ000010
Post #1003517 9th Aug 2023 6:54pm
Devon-Rover
Simply any Land rover which could run ABS would run a TDJ000010 CV If you had a defender / disco / range rover classic from like 1995> then ABS or not then it didn't matter you had the ring machined onto the CV to save costs / confusion.
Same was 2007> one shaft / CV combo fits all.
Thumbs Up Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #1003527 9th Aug 2023 7:29pm
olistr
Germany
Perfect,
Thx again for the help
Post #1003553 10th Aug 2023 4:22am
