![]() | Home > Technical > td5 abs |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 923 ![]() ![]() ![]() |
The 'ring' is part of the the CV joint the sensor can be seen entering through the top of the swivel pin. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
olistr Member Since: 29 Dec 2022 Location: BW Posts: 67 ![]() ![]() |
Hi does that mean there are abs specific cv joints? Couldn‘t find any reference on lrworkshop. Or is that „ring“ in all cv-joints?
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 788 ![]() ![]() ![]() |
I don't know the precise answer, but have a look here.... In the picture you can see the ABS notches
https://www.lrworkshop.com/parts/TDJ000010 |
Simply any Land rover which could run ABS would run a TDJ000010 CV If you had a defender / disco / range rover classic from like 1995> then ABS or not then it didn't matter you had the ring machined onto the CV to save costs / confusion.
Same was 2007> one shaft / CV combo fits all. ![]() |
Perfect,
Thx again for the help |
