![]() | Home > Technical > Sealing gaps at corners of 2nd row floor |
Afternoon all,
After fitting the rear floor panel on my rebuild, there are gaps in the four corners which obviously need sealing up somehow (see photo below). ![]() Click image to enlarge ![]() Click image to enlarge there is no metal lip below the floor in these areas hence the gap, even though i applied neoprene seal around the whole perimeter. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 577 ![]() ![]() ![]() |
The black gunk you need is https://www.woolies-trim.co.uk/p-1979-body-caulking-10-strips
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 788 ![]() ![]() ![]() |
I used "windscreen butyl strip" off ebay
cheers both,
I already have some of that Woolies caulking strip so will add it to the list of bits to address where I can see daylight where I shouldn't be able to! Thanks Steve 02' 110 TD5 Double Cab Rebuild Thread |
