Home > Technical > Sealing gaps at corners of 2nd row floor |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
Afternoon all,
After fitting the rear floor panel on my rebuild, there are gaps in the four corners which obviously need sealing up somehow (see photo below). Click image to enlarge Click image to enlarge there is no metal lip below the floor in these areas hence the gap, even though i applied neoprene seal around the whole perimeter. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
24th Jul 2023 1:14pm |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 569 |
The black gunk you need is https://www.woolies-trim.co.uk/p-1979-body-caulking-10-strips
24th Jul 2023 1:43pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 743 |
I used "windscreen butyl strip" off ebay
24th Jul 2023 1:57pm |
cheers both,
I already have some of that Woolies caulking strip so will add it to the list of bits to address where I can see daylight where I shouldn't be able to! Thanks Steve 02' 110 TD5 Double Cab Rebuild Thread |
24th Jul 2023 2:04pm |
