Home > Puma (Tdci) > Puma centre air vent and a cold arm!
Norfolk-n-chance
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Hello chaps,
Has anyone done a mod on the Puma dash centre air vents? The fixed ones between the round ones?
In the current warm weather I’ve been using the aircon a bit, while the round air vents are ok for changing the direction of airflow etc, the centre ones are fixed and just seem to blow cold air on my left arm. I wondered if there’s a mod where they can be closed or at least made to direct the airflow upwards?
Thanks in advance
Mark “a committee is a group of people who individually can do nothing, but as a group decide nothing can be done.”
Post #1001353 23rd Jul 2023 3:32am
AMBxx
I've seen a replacement console that has adjustable centre vents.
My wife just stuffed a small sock into the vent!
Post #1001355 23rd Jul 2023 6:40am
Dinnu
Only seen double din facia with adjustable vents. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1001356 23rd Jul 2023 6:52am
Norfolk-n-chance
Rolling with laughter To be honest, it’s my wife who’s got more of an issue with it than me!! She’s tried a hat (over the vent, not wearing it!) various pieces of paper, even a stack of dairy milk bars, but she hasn’t tried the sock fix.
I’ll have to tell her! Laughing “a committee is a group of people who individually can do nothing, but as a group decide nothing can be done.”
Post #1001360 23rd Jul 2023 8:51am
I don't think there's an easy solution other than shoving a sock down the vent pipe behind the dash. (If you unscrew and pull out the centre panel you can stuff your socks into the pipe itself).
I've always found those centre vents, all four of them, a bit naff and unsatisfactory. For more than ten years I've been failing to get round to doing something about it! My plan is to modify the heater airbox so that the centre fixed vents are deleted and the directional round vents are always unheated fresh air. It's do-able, (certainly on my non-AC airbox, but involved and time-consuming.
Post #1001367 23rd Jul 2023 10:02am
Norfolk-n-chance
Is the removal of the centre panel a straightforward job?
Is it just a case of removing the 4 Allen bolts? “a committee is a group of people who individually can do nothing, but as a group decide nothing can be done.”
Post #1001376 23rd Jul 2023 10:44am
DAZ110
Changing the airflow direction using the right knob usually helps with this problem. You can get a mix between blowing on the windscreen and toward the face/feet.
Post #1001377 23rd Jul 2023 10:52am
Two screws with Torx socket heads, then CAREFULLY pry the panel forwards (there are clips as well as the screws) and free. There are many wires to the switches, radio, etc., so take care. You can usually get a couple of inches without disconnecting anything.
Post #1001386 23rd Jul 2023 11:38am
AMBxx
Aren't they in 2 parts?
Post #1001402 23rd Jul 2023 1:43pm
Norfolk-n-chance
Thanks, I’ll check it out Thumbs Up “a committee is a group of people who individually can do nothing, but as a group decide nothing can be done.”
Post #1001426 23rd Jul 2023 5:47pm
Dinnu
The genuine single din is one molded part. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1001470 24th Jul 2023 1:57am
Naks
3D print a plug and glue in on the actual aircon vents inside the dash? --
Post #1001474 24th Jul 2023 7:25am
DAZ110
Make up some kind of deflector to change the airflow direction that fits on the outside?
Post #1001478 24th Jul 2023 8:02am
Norfolk-n-chance
I think, ideally I’d like to somehow deflect the airflow rather than stop it altogether. That was also the idea of the wife’s dairy milk deflector shield! Laughing
3D print something…. You could be on to something there, I don’t know anyone with one but I’m sure I could find someone… “a committee is a group of people who individually can do nothing, but as a group decide nothing can be done.”
Post #1001490 24th Jul 2023 9:11am
Naks
Yes, the ideal would be instead of the airflow aimed at the gearlever, it should be re-directed upwards and towards the windoes, so that the cool air then descends into the cabin onto the occupants. Thumbs Up --
Post #1001638 25th Jul 2023 8:44am
