![]() | Home > Puma (Tdci) > Puma centre air vent and a cold arm! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17722 ![]() ![]() ![]() |
I think that you are overestimating the amount of thinking that went on. There appears to have been relatively little.
I think the design was more for the 110, where the air had to be sent to the rear seats, and they figured the front occupants had the adjustable circular vents. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1111 ![]() ![]() ![]() |
I found the right distribution of air between windscreen, footwell and centre, plus there are two small smartphone holders in the centre vents. One actually holds the iPhone, the other a small notepad (paper), acting as deflectors (socks would not be approved by her
![]() There is a 3D print design, but it looks strange... https://www.thingiverse.com/thing:2656734 |
That looks like a self-emptying ashtray!
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7918 ![]() ![]() ![]() |
Defender Upgrades do a single din with top vents that move up and down, available in red or white
![]() https://defenderupgrades.co.uk/product/def...in-fascia/ The answer really is to turn off your aircon and open the window! ![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2058 ![]() ![]() |
Here’s the gloss black one:
https://defenderupgrades.co.uk/product/lan...din-facia/ |
…or carbon fibre look:
HTB Member Since: 24 Mar 2013 Location: Surrey Posts: 72 ![]() ![]() ![]() |
Check your heater cable exterior sheath isn't slipping where it clamps onto the valve in the engine bay - mine has been doing the same, but sorted with a small cable tie / tiewrap added to stop the slippage having made sure valve was in full closed position. super easy fix.... |
