Home > My Defender > New member with UK NAS AND 50TH Development Car
Page 5 of 11 <123 456 ... 91011>
sasdiscos
Lodelaner wrote:
Here's that photo of the fuel tank cradle and anti-roll bar location.
Excellent. Then yes. I will reinstate this with the rebuild.
Thanks so much.
Steve.
Post #1003687 10th Aug 2023 8:44pm
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
Front ARB is like this.
 JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #1003688 10th Aug 2023 8:47pm
sasdiscos
Thanks.
In that case the spacers must be there for the lift and need to go.
Is that yours? Looks like a new car! Sterling work.
Steve.
Post #1003689 10th Aug 2023 9:00pm
Lodelaner
Sadly not mine, just one of the many reference photos I’ve collected when converting from tdi to V8. JB
Post #1003691 10th Aug 2023 9:10pm
Linds Hanson
I can never understand why Land Rover changed the tank cradle design on TD5/TDCI 90's from the NAS/50th set up? Perhaps they thought the rear antiroll mounts were not strong enough? But the cradle removal and refitting process on the later setup is brutal requiring much levering and bending of the cradle when the rear body is in place.[/i]
Post #1003739 11th Aug 2023 10:04am
Lodelaner
Hard to know, but my 50th went through them quite quickly. I think I fitted 2 genuine sets in 5 years. JB
Post #1003742 11th Aug 2023 10:27am
sasdiscos
Tanks out.
Brackets cut off.
Welds flattened down.
Now officially knackered!
Not too bad on the rust front. Just a bit of surface. Might need a new trailing arm mount bracket but will know when I’ve cleaned up.
Post #1003779 11th Aug 2023 3:21pm
Lodelaner
Thumbs Up JB
Post #1003781 11th Aug 2023 3:34pm
sasdiscos
Does anyone know the ral code for a nas defender in red?
Steve
Post #1003805 11th Aug 2023 7:37pm
NickMc
For a red (which fades badly as a colour) you’d be much better taking it to an automotive paint supplier and getting it colour matched with the analyser machine that takes a bunch of images and matches the colour.
I have sent you a pm about a guy I remembered had parts.
Post #1003818 11th Aug 2023 8:39pm
Lodelaner
It should be Portofino red, on Discoveries and similar ange Range Rovers it was called Arrow Red and Corallin Red.
Just looked it up and it’s code CUF 390. https://rimmerbros.com/Item--i-RTC5728VA
Although there is some sense in getting a colour match from the paint, I’d prefer to take the approach of cutting and polishing the red back to reveal the original colour and then matching the paint. As it’s a solid you can get the original paint dusted over and the whole car will look even and original. JB
Post #1003824 11th Aug 2023 9:19pm
Dinnu
I am following this thread with interest. Lucky find, and good work/progress.
sasdiscos wrote:
Tanks out.
It does seem that there once the original trailing arm chassis bracket, which is welded to the top of the chassis. Wonder if it was a LR modification. Seem a bit weak as they are, as the sidewall of the chassis is only 2mm plate. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1003835 12th Aug 2023 5:20am
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Can't wait to see this finished. Love a nas 90 in Portofino red.
Post #1003837 12th Aug 2023 5:46am
Martin
Site Admin
RAL doesn’t normally cross-refer to original factory paint colours.
You might find something close, but not the same.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1003843 12th Aug 2023 7:13am
sasdiscos
Looking at it. I’m going to have to fit new trailing arm brackets.
Looks like they were modified to accommodate the side tanks.
I can get the brackets easy enough.
Has anyone done it on here and have any pointers?
My welding is good but not sure if I want to weld such a safety critical structural part myself.
Steve
Post #1003845 12th Aug 2023 8:02am
