Home > Puma (Tdci) > Black smoke
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Black smoke
On my 2.4 I'm getting smoke on over run and acceleration. It's been suggested it could be cracked manifold inlet. Engine is standard with no mapping or upgrades and passes mot fine. Any thoughts ? Mileage is 70k and has no loss of power
Post #999450 10th Jul 2023 12:29pm
Ianh
Have you a code reader to see if any diagnostic trouble codes have been recorded ?
Post #999452 10th Jul 2023 12:47pm
AndyS
Have you replaced the injector seals yet?
Post #999454 10th Jul 2023 1:02pm
ginjez
No fault codes are showing and injector seals haven't been touched.
Post #999463 10th Jul 2023 1:36pm
Dinnu
On overrun shouldn’t the injectos be switched off by the ECU? Strange that you see black smoke (over fuelling) during overrun. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #999473 10th Jul 2023 2:05pm
Ianh
Wild guess, but fuelling issues and lack of DTC’s on a 2.4 generally point to a VCV issue. However I’ve not read of it causing your specific symptoms, so someone like Blackwolf may be able to confirm if it could be the VCV in your case.
Post #999478 10th Jul 2023 2:20pm
barbel jim
IIRC wasn’t there something about the brake pedal switch ?? Something along the lines of not working causes smoke ?? I might be making it up Laughing but sure I herd it somewhere??
Post #999490 10th Jul 2023 2:50pm
Ianh
Do you mean the clutch switch, fitted on the Clutch master cylinder? This does interact with the engine ECU on gear changes, but expect would provide a DTC if having issues and I think the OP’s issues are not during gear changes.
Post #999494 10th Jul 2023 3:39pm
barbel jim
Could well be that…. Laughing never had a 2.4 but one of the random things I remembered!! Whistle
Post #999501 10th Jul 2023 4:22pm
Jem_90
United Kingdom 2011 Defender 110 Puma 2.4 USW Baltic Blue
I had a faulty EGR valve that made our Landy smoke like crazy.
RAC man hit the EGR housing with a hammer (I kid you not) Rolling with laughter and it was as good as new. https://www.instagram.com/baltic_blue_defender/
Post #999506 10th Jul 2023 4:46pm
Ianh
Sticking EGR valves tend to record DTC’s
Post #999530 10th Jul 2023 7:32pm
