Home > Puma (Tdci) > Black smoke |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2092 |
Have you a code reader to see if any diagnostic trouble codes have been recorded ?
10th Jul 2023 11:47am |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 |
Have you replaced the injector seals yet?
10th Jul 2023 12:02pm |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1766 |
No fault codes are showing and injector seals haven't been touched.
10th Jul 2023 12:36pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3449 |
On overrun shouldn’t the injectos be switched off by the ECU? Strange that you see black smoke (over fuelling) during overrun. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
10th Jul 2023 1:05pm |
Wild guess, but fuelling issues and lack of DTC’s on a 2.4 generally point to a VCV issue. However I’ve not read of it causing your specific symptoms, so someone like Blackwolf may be able to confirm if it could be the VCV in your case.
10th Jul 2023 1:20pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1431 |
IIRC wasn’t there something about the brake pedal switch ?? Something along the lines of not working causes smoke ?? I might be making it up but sure I herd it somewhere??
10th Jul 2023 1:50pm |
Do you mean the clutch switch, fitted on the Clutch master cylinder? This does interact with the engine ECU on gear changes, but expect would provide a DTC if having issues and I think the OP’s issues are not during gear changes. |
10th Jul 2023 2:39pm |
Could well be that…. never had a 2.4 but one of the random things I remembered!! |
10th Jul 2023 3:22pm |
Jem_90 Member Since: 10 May 2019 Location: Oxon Posts: 54 |
I had a faulty EGR valve that made our Landy smoke like crazy.
RAC man hit the EGR housing with a hammer (I kid you not) and it was as good as new. https://www.instagram.com/baltic_blue_defender/ |
10th Jul 2023 3:46pm |
Sticking EGR valves tend to record DTC’s
10th Jul 2023 6:32pm |
