![]() | Home > Modifications & Maintenance (L663) > Wiper blades |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2719 ![]() ![]() |
Bosch Aerotwin 22” blades fit with a small modification to the clip to clear the washer jet housing.
Part number AP22U. About £22 a pair. |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3019 ![]() ![]() |
Thank you, that sounds a lot more reasonable.
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
Try giving them a good clean with some meths, you’ll be amazed how they supple up and come back to life ![]() If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
TomekW Member Since: 21 Feb 2015 Location: Warsaw Posts: 197 ![]() ![]() ![]() |
Bosch Aerotwin dedicated to L663
front 339700900C (A 990 S) rear 3397016387 (A 334 H) 2021 Defender 90 D250 1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3706 ![]() ![]() ![]() |
Are Aerotwin what it comes from the factory with?
Apparently "not currently available from Bosch. No other options except Genuine LR" Oh, and Britpart ☹️ |
Going to try these.
German, so good chance they'll be okay https://www.ebay.co.uk/itm/125676405325?mk...media=COPY |
These didn't work, they fit on okay but both wipers don't clear a patch of screen at the right hand side, as if the rubber blade is lifting off the glass.
l will update this, because it might save you £50 when you need new wiper blades.
The LR ones are £70 for a pair. l tried two alternatives, both German manufacturers and neither worked properly. lt's as if Land Rover designed it so only theirs will work properly. The spring steel arms on the LR blades are much stronger and the pivot has more movement. Anyhow, if you buy the ALCA branded wipers for Defender L663 the rubber blade is the same. You can take one of the plastic ends off your original wiper blades and insert the ALCA rubber After that it works perfectly for a total of £20. On the inside of one of the plastic end caps there's two tiny plastic tabs you have to remove. And the ALCA blades need to be trimmed in length around 1cm. |
Hazelhunter Member Since: 18 Nov 2020 Location: Hohenlohe Posts: 19 ![]() ![]() |
Hello lightning, do you have an order number for the ALCA wiper blades?
Thanks very much |
