Home > Modifications & Maintenance (L663) > Wiper blades
lightning
Wiper blades
Can anyone recommend a good set of aftermarket front wiper blades for the new Defender?
Mine are juddering across the screen on the slower "intermittent" setting after only 5,000 miles, it happens after the hot weather last week.
Land Rover want £70 for a pair, which seems somewhat excessive.
Post #997046 21st Jun 2023 8:07pm
Retroanaconda
Bosch Aerotwin 22” blades fit with a small modification to the clip to clear the washer jet housing.
Part number AP22U. About £22 a pair.
Post #997050 21st Jun 2023 8:17pm
lightning
Thank you, that sounds a lot more reasonable.
Post #997056 21st Jun 2023 9:08pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Re: Wiper blades
Try giving them a good clean with some meths, you’ll be amazed how they supple up and come back to life Thumbs Up Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #997063 21st Jun 2023 9:36pm
TomekW
Poland 2003 Defender 110 Td5 SW Bonatti Grey
Bosch Aerotwin dedicated to L663
front 339700900C (A 990 S)
rear 3397016387 (A 334 H) 2021 Defender 90 D250
1998 TUL
1997 TUM FFR
2003 Defender 110SW Td5
1985 ExMOD 110 ST 3.9 V8
1971 Series IIa Lightweight
Post #997068 21st Jun 2023 10:33pm
Co1
Are Aerotwin what it comes from the factory with?
Post #997078 22nd Jun 2023 6:10am
lightning
Apparently "not currently available from Bosch. No other options except Genuine LR"
Oh, and Britpart ☹️
Post #998056 30th Jun 2023 3:51pm
lightning
Going to try these.
German, so good chance they'll be okay
https://www.ebay.co.uk/itm/125676405325?mk...media=COPY
Post #998065 30th Jun 2023 4:21pm
lightning
These didn't work, they fit on okay but both wipers don't clear a patch of screen at the right hand side, as if the rubber blade is lifting off the glass.
Post #999390 9th Jul 2023 10:33pm
lightning
l will update this, because it might save you £50 when you need new wiper blades.
The LR ones are £70 for a pair.
l tried two alternatives, both German manufacturers and neither worked properly. lt's as if Land Rover designed it so only theirs will work properly.
The spring steel arms on the LR blades are much stronger and the pivot has more movement.
Anyhow, if you buy the ALCA branded wipers for Defender L663 the rubber blade is the same. You can take one of the plastic ends off your original wiper blades and insert the ALCA rubber
After that it works perfectly for a total of £20.
On the inside of one of the plastic end caps there's two tiny plastic tabs you have to remove. And the ALCA blades need to be trimmed in length around 1cm.
Post #1001314 22nd Jul 2023 6:44pm
Hazelhunter
Germany
Hello lightning, do you have an order number for the ALCA wiper blades?
Thanks very much
Post #1001483 24th Jul 2023 8:52am
