Home > Puma (Tdci) > Puma First Service - Using an Independent |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Ye thats right bud NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
6th Feb 2009 5:44pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 |
I do all the routine servicing on both of mine, but is due into the local dealers next month to check the product recalls, before the next trip California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
10th Feb 2009 8:43pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5034 |
brake pipe, breather location, sump there is at least one other Mike |
11th Feb 2009 12:04am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Again, are these strictly recalls or just service bulletins? One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
11th Feb 2009 10:35am |
Exactly. If they were recalls they would have recalled all the models affected for rectification. |
12th Feb 2009 7:48pm |
If they are just service bulletins, does that mean we have to have exhibited the symptoms before they rectify the issue (i.e breather problems, sump collision, vacuum pump leak...).
Can we just request that they change the parts to prevent problems arising (so long as the part numbers/VIN confirm eligibility)? One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
13th Feb 2009 8:42am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4646 |
I had an early oil and filter change done at an independent. Shortly afterwards I noticed oil dripping from the oil filter. Went back for a new filter. Same problem developed. He was not using a genuine Land Rover filter. Anyway the Defender went into a maindealer to check the engine management light (faulty senser) and I mentioned about the leaking engine oil filter. They changed it with the genuine article and I have no leaks. They said it must have been a faulty seal. I did'nt say that I'd had it done by someone else who used the non Land Rover filter. Don't feel guilty either!
The independent supplied my Defender and has many years Land Rover experience. Swears by the the filters he uses. Must be the very fine synthetic oil in the Tdci. Funnily enough when the independent changed the first leaking filter he topped up the engineoil to compensate for the bit lost during the changing from one filter to another. The maindealer did'nt so I must top it up on the weekend.I am sure the leaky filter would have done no harm as it was a miniscule amount.So it seems best to stick to the genuine article for services. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
19th Feb 2009 7:42pm |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
My dealer just replaced my filter housing at my service. Never even noticed a leak.
They said it was Puma 110 - gone Series III 1973 - going strong |
19th Feb 2009 8:11pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 |
Checking the GTR
No Service Recalls for the Pumas. Only Service or Tehcnical Bulletins has been issued. (But at least the sump was hidden recall). Current Recalls are: Reference: BD148v3 (3) R einforce ABS Modulator Pressure Reduction Valve Reaction Plates (Export Markets) Reference: B215 (1) Purge Valve Fault - No Mil Light Illumination Reference: A273 (1) FAILURE OF THE LEFT HAND FRONT BRAKE HOSE, CAUSED BY THE HOSE Reference: A211 (1) DUAL MASS FLYWHEEL MATERIAL SPECIFICATION Reference: A148v3 (3) Reinforce ABS Modulator Pressure Reduction Valve Reaction Plates (UK) Reference: A/D255 (1) Winch Kit Power Interrupt Solenoid Malfunction Alll previous to 2005. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
19th Feb 2009 8:19pm |
