Home > Puma (Tdci) > Puma First Service - Using an Independent
Page 2 of 2 <12
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Ye thats right bud Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #6971 6th Feb 2009 5:44pm
Happyoldgit
Hmmm - but what actual recalls have there been since the Puma was introduced? I mean proper product recalls and not tech bulletins advising dealers of potential problems should a customer have a problem.
Post #7060 9th Feb 2009 3:09pm
TJ101
I do all the routine servicing on both of mine, but is due into the local dealers next month to check the product recalls, before the next trip Smile California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #7119 10th Feb 2009 8:43pm
mse
brake pipe, breather location, sump there is at least one other Mike
Post #7128 11th Feb 2009 12:04am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Again, are these strictly recalls or just service bulletins? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #7149 11th Feb 2009 10:35am
Happyoldgit
Exactly. If they were recalls they would have recalled all the models affected for rectification.
Post #7214 12th Feb 2009 7:48pm
alantd
If they are just service bulletins, does that mean we have to have exhibited the symptoms before they rectify the issue (i.e breather problems, sump collision, vacuum pump leak...).
Can we just request that they change the parts to prevent problems arising (so long as the part numbers/VIN confirm eligibility)? One that started out as a 2.4 TDCi 110 XS
Post #7218 13th Feb 2009 8:42am
spudfan
Ireland
I had an early oil and filter change done at an independent. Shortly afterwards I noticed oil dripping from the oil filter. Went back for a new filter. Same problem developed. He was not using a genuine Land Rover filter. Anyway the Defender went into a maindealer to check the engine management light (faulty senser) and I mentioned about the leaking engine oil filter. They changed it with the genuine article and I have no leaks. They said it must have been a faulty seal. I did'nt say that I'd had it done by someone else who used the non Land Rover filter. Don't feel guilty either!
The independent supplied my Defender and has many years Land Rover experience. Swears by the the filters he uses. Must be the very fine synthetic oil in the Tdci.
Funnily enough when the independent changed the first leaking filter he topped up the engineoil to compensate for the bit lost during the changing from one filter to another. The maindealer did'nt so I must top it up on the weekend.I am sure the leaky filter would have done no harm as it was a miniscule amount.So it seems best to stick to the genuine article for services. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #7543 19th Feb 2009 7:42pm
CapeLandy
South Africa
My dealer just replaced my filter housing at my service. Never even noticed a leak.
They said it was Confused Puma 110 - gone
Series III 1973 - going strong
Post #7548 19th Feb 2009 8:11pm
Eduardo
Checking the GTR
No Service Recalls for the Pumas. Only Service or Tehcnical Bulletins has been issued.
(But at least the sump was hidden recall).
Current Recalls are:
Reference: BD148v3 (3)
R einforce ABS Modulator Pressure Reduction Valve Reaction Plates (Export Markets)
Reference: B215 (1)
Purge Valve Fault - No Mil Light Illumination
Reference: A273 (1)
FAILURE OF THE LEFT HAND FRONT BRAKE HOSE, CAUSED BY THE HOSE
Reference: A211 (1)
DUAL MASS FLYWHEEL MATERIAL SPECIFICATION
Reference: A148v3 (3)
Reinforce ABS Modulator Pressure Reduction Valve Reaction Plates (UK)
Reference: A/D255 (1)
Winch Kit Power Interrupt Solenoid Malfunction
Alll previous to 2005.
Cheers Eduardo
Post #7549 19th Feb 2009 8:19pm
Page 2 of 2 <12
