Home > Technical > Bumper DRL wiring.
roche1800
Bumper DRL wiring.
Please can you advise …
I have fitted Ring DRL and there are 3 wires.
Positive with fuse to battery under seat
Negative to battery under seat
Orange (which has been extended using red cable) does this connect into the side light? The red wire in the picture attached?
(As a check would it work if it was shoved in from the front?
Post #995814 10th Jun 2023 9:05am
I would guess that the "lamp" wire you have there is to tell the DRL's that you've now turned your headlights ON, so would shut down the DRL's.
Just my thought anyway
Post #995823 10th Jun 2023 10:49am
roche1800
Does any one know where to connect the wire…
Post #995873 11th Jun 2023 7:35am
jcw
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Sidelight positive wire Thumbs Up
See this thread
https://www.defender2.net/forum/topic50542.html
Post #995878 11th Jun 2023 8:30am
roche1800
Thank you, would that be the red wire?
Post #995889 11th Jun 2023 10:12am
the_lincs_landies
Yes, generally speaking Red = Positive, Black = Negative. Though there are occasional exceptions to the rule where different coloured wires are used.
https://www.lrworkshop.com/connectors/defender-2007/colour/
(change the URL to reflect the age of your defender)
Post #995973 12th Jun 2023 8:25am
