Home > Puma (Tdci) > Why motor goes into limp mode when needle risers |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
hi is your water flowing in your radiator expansion tank worth a look iv seen thermostats put in upside down . check the finials is clean in you radiator too .
Regards Andy |
5th Jun 2023 3:13pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2036 |
Have you a code reader to obtain the Diagnostic Trouble Code(s) that are triggering the limp mode ?
Also, on the 2.2 you have a coolant temperature sensor, so worth checking that and it’s wiring are ok. See https://www.defender2.net/forum/post390785.html second post down has a diagram on location. |
5th Jun 2023 4:12pm |
rillas Member Since: 27 May 2012 Location: warilla nsw 2528 Posts: 16 |
Thanks will check out weekend
7th Jun 2023 11:17am |
