Home > Puma (Tdci) > Why motor goes into limp mode when needle risers
rillas
Australia 2003 Defender 90 Td5 HT Tonga Green
Why does my 2.2 heat needle goes up just after Limp mode kicks in sit for 20 mins needle drops no water loss and drives off if nothing was wrong new water pump new silicon hoses new thermostat new bowl cup please help I am at send
Post #995108 5th Jun 2023 9:45am
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
hi is your water flowing in your radiator expansion tank worth a look iv seen thermostats put in upside down . check the finials is clean in you radiator too .
Regards
Andy
Post #995180 5th Jun 2023 4:13pm
Ianh
Have you a code reader to obtain the Diagnostic Trouble Code(s) that are triggering the limp mode ?
Also, on the 2.2 you have a coolant temperature sensor, so worth checking that and it’s wiring are ok.
See https://www.defender2.net/forum/post390785.html second post down has a diagram on location.
Post #995194 5th Jun 2023 5:12pm
rillas
Thanks will check out weekend
Post #995422 7th Jun 2023 12:17pm
