Home > Puma (Tdci) > Help identifying a part!
Stephane
Canada
Dear Defender community, after installing (successfully!) a cruise control kit, I was left with a part that fell to the ground from the engine compartment... oh no! It was found right in front of the foot well where the pedals are bolted through. It is metal, brass or steel, hard to tell. Can anyone recognize the pictures?
Post #994319 28th May 2023 3:04pm
Stephane
Canada
With pictures...
Post #994320 28th May 2023 3:40pm
Stephane
Canada
With pictures
Post #994321 28th May 2023 3:41pm
TexasRover
what defender is this?
Post #994328 28th May 2023 5:37pm
Stephane
Canada
2008 Defender 110 wagon.
Post #994329 28th May 2023 5:46pm
jcw
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Looks like the underside part of the aerial fixing where it passes through the hole in the wing.
Post #994330 28th May 2023 6:06pm
wyvern
JCW - That is it exactly .. its from a wing mounted aerial
I had my aerial out last week replace it with the Nacca.. digital one, and that is a part of the original aerial that I removed .. I was looking at the pictures and knew I had seen that part recently !!
So its nothing to do with you fitting the cruise control - hope that helps !
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #994334 28th May 2023 7:10pm
Stephane
Canada
Mystery solved! And that also explains why the radio reception was spotty. The aerial is rotten. Thanks all!
Post #994339 28th May 2023 7:54pm
