Home > Td5 > Smoking on cold start-up
Hideousfish
United Kingdom 2007 Defender 90 2.5 TD SW Barolo Black
Hiya
I'm 'lucky enough' to own a 2007 90 TD5, really low mileage (60k) but had a catalogue of issues over the years. Engine been rebuild, had new injectors, turbo, starter motor, etc etc. One thing that I can't seem to eliminate is the smoking exhaust on cold start up. It goes after a few minutes of running and is s sweet as a nut when it's going. The garage that look after it have run out of ideas. Any suggestions? Or is it simply the lovely Ford engine?
Post #993868 24th May 2023 1:47pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
What colour is the smoke?
Also - it's not a Ford engine. 100% Land Rover! 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #993869 24th May 2023 1:50pm
Hideousfish wrote:
... Or is it simply the lovely Ford engine?
You can rule this out straight away, there is nothing Ford about the TD5 engine.
Perhaps you have a TDCi not a TD5 (2007 would be a very late TD5) in which case smoke on start up seems to be extremely common, probably normal.
Figure out what you have and let us know!
Post #993870 24th May 2023 1:52pm
Hideousfish
it's just grey smoke, not oil for sure, just wonder if it's burning off diesel that's gathering when it's sitting? Forgive me, I'm not familiar with the oily bits, just the driving bits Smile
Post #993871 24th May 2023 1:52pm
Hazza
Can you confirm if it's. Td5 or tdci? A photo of the engine bay would confirm it, but if you look under the bonnet and the top of the engine looks like it has a cupholder built in then you have a tdci. 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #993872 24th May 2023 1:56pm
Hideousfish
Looks like a TDCi would you say with a 'cup-holder? lol
Post #993873 24th May 2023 2:08pm
Hazza
Yep - Tdci. That's a Ford engine!
Not sure on these engines I'm afraid - maybe someone can move this to the correct section and you'll get some better input. 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #993874 24th May 2023 2:13pm
Hideousfish
Thanks, that's a start then, assuming the 2.4 Ford Puma engine? I can ask in that bit of the forum
Post #993875 24th May 2023 2:17pm
