![]() | Home > Puma (Tdci) > Rear 90 mud flaps - basic question |
Sjmmarsh Member Since: 01 Jan 2023 Location: Lincs Posts: 59 ![]() ![]() ![]() |
I am new to the land of defenders and need to sort some rust out on one of the mud flaps. The bracket is held on with 3 nuts - are the studs captive in the cross member, or do I need to get a spanner inside there?
I can check by loosening the nut, but if they aren’t captive they won’t be easy to tighten! Steve |
Kevlar Member Since: 28 Oct 2020 Location: Prague Posts: 78 ![]() ![]() ![]() |
Hi, in my case it was both, some were clinch nuts and some normal nuts.
Once I got them off I replaced them all with clinch nuts. It wasn’t so easy to remove them as they were old and rusty Kev |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
just has it says above mine came out ok use a bit of copper slip for next time they rust very quick
Thanks. It sounds like a WD-40 or Plusgas soaking overnight is needed first.
Steve |
