![]() | Home > Td5 > Rear seats - What am I missing? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5848 ![]() ![]() |
My 110 seats (original) don’t have brackets there. Just on the C pillar.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5920 ![]() ![]() ![]() |
Thanks LA. How do you stop your seats from folding forwards?
Mine is a 1999 TD5 maybe the C-Pillar catch came later? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1207 ![]() ![]() ![]() |
I had a 1999 which had the latch on the c-pillar.
The only catch I have is down towards the bottom of the sear base (has a sliding catch to release the seats)
This sliding catch stops the seat tipping forwards, but I have nothing to stop the rear back rest part of seat folding forwards. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Nutter Member Since: 15 Sep 2014 Location: Birchington Posts: 25 ![]() ![]() |
Hello i think that catch locks the two seats together when up 60/40 and the one down the bottom should tip them.
If you look at this add. He is selling the retainers that I have on the Cpost and no clips on the two parts of the seat https://www.defender2.net/forum/topic86511.html |
Yes exactly that second picture is what I had on the 1999 which i retrofitted to my DCPU which normally has the rear seats fixed mounted with a bracket on each side giving you no access.
I had to make two brackets to secure the back side of these latching brackets. Without them you would not have a lot of resistance to anything heavy sliding forward |
Cheers chaps. I dont have that style seat back locking on mine. My seats are all locked at the bottom. Maybe due to being 33/33/33 seats.
However, I have it sussed. I remember two things. 1st - I had a set of seats in the loft - (dont we all) so I compared seat locking mechanisms and noticed its the same as the new seats I have and that there should be an extra pin/bolt for the catch to lock on to. 2nd - I had a bag of bits from the seller of the seats and a quick rummage revealed some spare / new pins/bolts Turns out the fasbric covers a threaded insert. After I found this and careful use of a sharp knife I now have (circled in blue) ![]() The seat backs now lock in position! Maybe tomorrows job is to swap the seats over. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
