Home > 130 > Towbar electrical socket
fatboyron
Looking for the correct towbar electrical connector for my 08 130 try Google and it comes up with a lot of different types is it the same as the Td5 one. I took the original one off when I was doing the chassis and never got round to get one but it got noted in the MOT
Post #990730 28th Apr 2023 6:07pm
kenzle8a
Post #990734 28th Apr 2023 6:41pm
fatboyron
Had a bit of time this morning finally got the stereo working and installed the rear towel electoral socket in the hole in the rear crossmember makes it nice and flush well worth the weight getting that bracket from IRD developments
Post #1035801 27th May 2024 10:29am
rustandoil
I should have bought a IRB plate or made one....
Post #1035807 27th May 2024 12:32pm
fatboyron
It's a first rate product but the checkout on the store is not straightforward and it was took a while to get delivered but it's very well made and makes installing in less than five minutes
Post #1035808 27th May 2024 12:36pm
TexasRover
I see you have the 'American Style' 2" tow socket. Very nice! Much better solution than the rather restricted European ball only solution.
Have this myself and few tow adapters allowing to quickly swap between a high and low trailer mount or a solid and simple a bicycle carrier.
Post #1035810 27th May 2024 1:03pm
rustandoil
I drilled the three mounting holes directly in the crossmember recess.. They are close to the edge of the rectangular hole, but it works, but I still should have spent a few quid or milled a bit of plate.....
Post #1035811 27th May 2024 1:08pm
