Home > 130 > Towbar electrical socket |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
This is the one i got
https://rimmerbros.com/Item--i-LR005920 |
28th Apr 2023 6:41pm |
fatboyron Member Since: 28 Jul 2018 Location: Aylesham Canterbury Kent Posts: 116 |
Had a bit of time this morning finally got the stereo working and installed the rear towel electoral socket in the hole in the rear crossmember makes it nice and flush well worth the weight getting that bracket from IRD developments
Click image to enlarge |
27th May 2024 10:29am |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 773 |
I should have bought a IRB plate or made one....
27th May 2024 12:32pm |
It's a first rate product but the checkout on the store is not straightforward and it was took a while to get delivered but it's very well made and makes installing in less than five minutes
27th May 2024 12:36pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1118 |
I see you have the 'American Style' 2" tow socket. Very nice! Much better solution than the rather restricted European ball only solution.
Have this myself and few tow adapters allowing to quickly swap between a high and low trailer mount or a solid and simple a bicycle carrier. |
27th May 2024 1:03pm |
I drilled the three mounting holes directly in the crossmember recess.. They are close to the edge of the rectangular hole, but it works, but I still should have spent a few quid or milled a bit of plate.....
27th May 2024 1:08pm |
