![]() | Home > Maintenance & Modifications > Door draft |
Except they don't ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 368 ![]() ![]() ![]() |
I thought I had a lot of wind noise coming into the cab through the door gaps. I had them adjusted many times and also fitted new genuine seals.
Then a couple of months ago for an unknown reason I put my ear to the window glass and discovered the noise was actually coming from between the glass and the door frame. To test the theory I put masking tape across the glass and frame to create a seal and went out for a test drive. Wow! What a difference.. Such a huge reduction in road noise and the whoosh when cars pass in the other direction. I have newish doors and seals so need to figure out a solution. Adding additional shims to the channel guides has been suggested. Anyone got any other ideas? TD5 hardtop to Puma inspired Poptop - my build thread 2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
