![]() | Home > Maintenance & Modifications > Door draft |
TomB8 Member Since: 17 Nov 2022 Location: West Sussex Posts: 117 ![]() ![]() ![]() |
Wait about 6 weeks and you'll be glad of the airflow!
Can you not adjust your striker to hold the door closed more? |
Poulstonb Member Since: 30 Jun 2022 Location: Styal Posts: 88 ![]() ![]() |
I’ve a posh one with air con !!!
Doors seems tight at top already |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
I cannot provide a solution, but I can confirm that mine has the same issue. I have on occasion stuffed a fleece down there to stop the draft in the Winter, which appeared to be an effective draft excluder! 2005 Td5 90 XS
1989 V8 110 CSW |
Ooooo yes very fancy!
Have you watched all of Britannica restorations videos on door seals? You could maybe tweak the top out a bit and put your striker a few mm further in. Be warned, you may be there a while fiddling around to get it right. |
It's difficult to be sure from the photo but it appears that the hardtop side is inboard of the tub capping. It may help to slacken the mounting bolts off and push the side outwards, so that it better aligns with the door. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Evil Elsie Member Since: 25 Feb 2023 Location: Cumbria Posts: 206 ![]() ![]() ![]() |
I feel your pain.....
Good luck 👍👍 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
Might be easier and quicker to just stick on some of this:
https://www.toolstation.com/stormguard-jum...rip/p95977 |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 795 ![]() ![]() ![]() |
I have had a similar issue with aftermarket seals on another vehicle- we ended up very carefully slitting the seal and then feeding some rubber pipe into the hollow section to make the seal slightly deeper profile.
Its a bit of a bodge- but a good quality bodge....... Chris |
Thanks all
Sounds like a bodge and hope for the best approach might be in order |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17670 ![]() ![]() ![]() |
If the hinges and lock striker are correctly adjusted, the next step is usually to bend the door carefully to make it fit better.
dainger Member Since: 08 Feb 2022 Location: Harpenden Posts: 69 ![]() ![]() ![]() |
Great advise… hinge adjustment is spot on for mine OCD alignment.
Managed to undo the bolt that holds the top to the body and pull the top out a few mm.
Definitely an improvement, Will try the striker plate next . How do you adjust the hinge ? |
My main issue was the rubber seal was pushing the hinge out, so removing it allowed for the seal to be seated properly which resolved my issue.
Are you sure your doors are true? My old 90’s doors were bow shape, just subtle but enough to cause a right nighmare with keeping it water tight’ish. new doors and bulkhead sorted that issue. (That was supposed to be my “cheap” landy). Lol. |
Jabberwocky Member Since: 27 Oct 2021 Location: Luxembourg Posts: 235 ![]() ![]() |
To quote Land Rover customer service manual
‘They all do that sir’ |
