![]() | Home > Technical > Coolant issues |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1154 ![]() ![]() ![]() |
Use a infrared temp meter to check the block temp after some driving. With what you describe sound more like an electrical, most likely earthing issue.
Inguz Member Since: 06 Sep 2020 Location: In the wild Posts: 101 ![]() |
I was thinking (hoping) it’s an electrical issue. I don’t want to pull the head again. Thanks for the idea, I’ll get on it.
Does the temp gauge always rise when you turn the heater on?
Yes every time. Some times it rises then drops a little but it’s always higher than when the heater is off
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1434 ![]() ![]() ![]() |
Could well be an earth issue. Mine was related to the earth post, in the seat box y the drivers seat .I ran a new cable from said earth post to chassis, cured my dancing temperature. Just use a jump lead to a good earth point, and check the earths. It’s pretty quick and simple.
