Home > Technical > Coolant issues |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1050 |
Use a infrared temp meter to check the block temp after some driving. With what you describe sound more like an electrical, most likely earthing issue.
22nd Apr 2023 3:03pm |
Inguz Member Since: 06 Sep 2020 Location: In the wild Posts: 101 |
I was thinking (hoping) it’s an electrical issue. I don’t want to pull the head again. Thanks for the idea, I’ll get on it.
22nd Apr 2023 4:13pm |
Does the temp gauge always rise when you turn the heater on?
22nd Apr 2023 4:53pm |
Yes every time. Some times it rises then drops a little but it’s always higher than when the heater is off
22nd Apr 2023 5:08pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1423 |
Could well be an earth issue. Mine was related to the earth post, in the seat box y the drivers seat .I ran a new cable from said earth post to chassis, cured my dancing temperature. Just use a jump lead to a good earth point, and check the earths. It’s pretty quick and simple.
22nd Apr 2023 5:20pm |
