Home > Td5 > Td5 won't start in Waitrose!
mini Anaconda
Hi all,
I've got a 2002 Td5 that has just broken down in Waitrose Embarassed
I went to start it and it was as if the battery was flat as it was turning over very very slowly and then stopped turning over. I put jump leads on it and that didn't improve matters, it still turned over very slowly.
I bump started it and it started fine and drove 15 minutes back from Waitrose. I'm now home and it isn't turning over at all, the starter motor is just clicking.
I have cleaned up the battery terminals and leads (on the battery end) and the battery is reading 12.6 volts with the engine off so that would appear to be okay.
Any ideas of things to check?
Many thanks BORG - Bucks & Oxon 4x4 Response Group
Post #989908 22nd Apr 2023 10:42am
ibexman
Starter rebuild
Post #989909 22nd Apr 2023 10:45am
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
If you haven't already check the earths.
Chris
Post #989919 22nd Apr 2023 11:26am
geobloke
And by earths Chris means the body, engine to chassis earth straps.
Post #989929 22nd Apr 2023 1:45pm
grafty99
I would wager it's the starter solenoid, common for them to wear out and fail pretty suddenly. You can rebuild the solenoid with a kit Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #989931 22nd Apr 2023 1:56pm
mini Anaconda
Thanks for all the suggestions guys. Plenty to keep me busy...
Having just tried it again, I noticed that the temperature gauge moves all the way to hot when turning the ignition on and remains there (the engine is cold) which it has never done before.
Is this related or any suggestions based on that? BORG - Bucks & Oxon 4x4 Response Group
Post #989932 22nd Apr 2023 2:01pm
geobloke
The weird gauges is an earth issue too 👍
Post #989933 22nd Apr 2023 2:07pm
mini Anaconda
All the earths have been cleaned up which has resolved the awol temperature gauge but not the starting.
Tapping the starter motor with a hammer and block of wood now has the starter motor turning over fast enough to start the engine so it looks like that is the cause of the problems.
I'll get a rebuild kit ordered.
Thanks again for the help. Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #989979 22nd Apr 2023 6:34pm
On a TD5 you'll probably be able to overhaul the solenoid an solve the problem.
Post #989997 22nd Apr 2023 8:01pm
Oldowner
When I had a td5 I used to put new contacts in the solenoid on a yearly basis at £15 to prevent getting stranded.
Post #990006 22nd Apr 2023 10:25pm
geobloke
Well done there Thumbs Up
Fingers crossed that the solenoid refurb kit fixes your slow turn-over. If you have to buy a replacement starter motor it is worth every penny to go with a Denso unit.
Post #990026 23rd Apr 2023 9:46am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
When I had this exact same issue (in Aldi) I put a jump lead from the engine to the battery and it was fine. It was down to the main earth point on the transfer box.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #990088 23rd Apr 2023 6:53pm
mini Anaconda
Thanks Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #990128 24th Apr 2023 7:17am
mini Anaconda
The solenoid rebuild kit didn't solve the problem so a new Denso unit was bought and that did solve the problem.
Never seen inside a starter motor before so took it apart and the windings(?) were really quite dirty and rusty. It has four brushes, two of which were completely worn away, the retaining spring on one of the others was broken, no surprise it didn't work. Don't know if you can buy the parts but its in the bin now.
Thanks for the replies. BORG - Bucks & Oxon 4x4 Response Group
Post #990820 29th Apr 2023 7:08pm
