Home > General & Technical (L663) > CB And Antenna Mount
Japseroony
England 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
Hi folks, I have just ordered a Defender 90 for delivery in July and need to have a CB for a planned trip in Sept.
So, the CB I have has a cigarette socket on it so is easily mountable and powered in the car but where are you guys mounting the antenna please?
I have a mag mount but am unsure of this on the roof?
Cheers in advance Thumbs Up Gas, Grass Or Ass - Nobody Rides For Free
"UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #989758 21st Apr 2023 10:24am
zilch
Australia
I have a Tuff Ant mount for the Antenna, utilises the existing passenger side bonnet hinge bolts,
the cable is run through the large rubber boot/grommet for the steering column..
The GME radio system is connected to the USB /12v fuse point via a piggy bank fuse holder/clip, used
fuse 2 on ours in the passenger glove box fuse compartment
No drilling, just the hole punched through the rubber grommet for the antenna coax cable..
 yet another pommie bar steward down under
MY20 110 P400 SE Defender
MY10 3.0 RR Sport
Post #989768 21st Apr 2023 10:42am
Tim in Scotland
I believe “Uncle Ray” (correction) on the D3 forum has been making some mounts for L663 that slide into the roof rails and bolt onto one of them Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed!
Post #989805 21st Apr 2023 1:42pm
Do you mean Uncle Ray, by any chance? Darren
Post #989809 21st Apr 2023 1:47pm
Japseroony
PM'ed Uncle Ray already asking about this Thumbs Up Gas, Grass Or Ass - Nobody Rides For Free
Post #989827 21st Apr 2023 3:56pm
markb110
This should give you some ideas as well
http://www.4x4cb.com/public/menu.cfm?Categ...e=Products
I use the PSM 1 Mount, using either the short 'rubber' arial when we were green landing as it is below the roof height and does not snag any low branchers as the wound whip versions do.
In the open such as Salisbury Plain or when marshalling then i use a 4 foot whip for the greater range.
If you know that you will be around lots of people it is best to secure the whip so not to accidently hit anyone.
Hope this helps
Post #989828 21st Apr 2023 4:06pm
Tim in Scotland
Yes and I’ve edited my post, thanks for pointing that out. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #989839 21st Apr 2023 5:52pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Ray's mounts are definitely up to the job, I have 2 on mine Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #989856 21st Apr 2023 9:32pm
WizzardPrang
A mag mount won't stick to the Defender's roof.
+1 for Ray's mount:
 Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #989858 21st Apr 2023 10:01pm
Japseroony
Just ordered one from Uncle Ray Thumbs Up
Wizzardprang, what antenna is that and what’s the approximate length? Gas, Grass Or Ass - Nobody Rides For Free
Post #989892 22nd Apr 2023 9:17am
Hairy Dan
I don't know whether you remember the aerial on mine when we were in Wales Russell but I bought a SIRIO TURBO 5000 without really looking at the length Embarassed At a smidge under 2 metres it is rather long but it does get great reception over a distance Laughing
 Cheers Ian
Kielder 4x4 Safari
Post #989918 22nd Apr 2023 11:23am
Japseroony
Hi Ian
I have a 1.55m one from 4x4CB that fits the mag mount I bought but was thinking of a short rubber one as we will not be that far from the lead car at any time.
I would take both and use accordingly but markb110 mentioned a shorter one was what got me thinking Thumbs Up Gas, Grass Or Ass - Nobody Rides For Free
Post #989920 22nd Apr 2023 11:32am
markb110
You just reminded me when i took part in the Scorpion Racing Novice Winch Challenge events.
In the first event i caught the springer arial in a low branches and basically straightened it out... Laughing
I then went for a Sirio thinking that range would be better.....it was until i snapped it green laning.
That's when i decided to go for the short rubber arial as they are good for 1.5 miles so perfect in a convoy then swap over to the longer springer when in open areas or the need to be in communication for driving days or when we would marshal at the Army Navigation events.
Post #989947 22nd Apr 2023 3:37pm
Japseroony
markb110, I also straightened out a springer whilst off road green driving and it kinked the roof!
What is the short rubber one you use please? Gas, Grass Or Ass - Nobody Rides For Free
Post #989950 22nd Apr 2023 3:46pm
markb110
An SWR meter is also worth getting as they don't cost much and it will help you check the grounding of your set before any damage occurs.
The link below will answer any questions.
I don't leave it permanently attached, only to periodically test. i also run a ground wire from the arial mount to the chassis so not to rely on the aluminium body.
Hope this helps, and have fun.
http://www.4x4cb.com/public/item.cfm?Refer...tegory=439
Post #989951 22nd Apr 2023 3:47pm
