Home > General & Technical (L663) > CB And Antenna Mount |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 |
I have a Tuff Ant mount for the Antenna, utilises the existing passenger side bonnet hinge bolts,
the cable is run through the large rubber boot/grommet for the steering column.. The GME radio system is connected to the USB /12v fuse point via a piggy bank fuse holder/clip, used fuse 2 on ours in the passenger glove box fuse compartment No drilling, just the hole punched through the rubber grommet for the antenna coax cable.. Click image to enlarge yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
21st Apr 2023 9:42am |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
I believe “Uncle Ray” (correction) on the D3 forum has been making some mounts for L663 that slide into the roof rails and bolt onto one of them Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! Last edited by Tim in Scotland on 21st Apr 2023 4:51pm. Edited 1 time in total |
21st Apr 2023 12:42pm |
Do you mean Uncle Ray, by any chance? Darren
21st Apr 2023 12:47pm |
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 829 |
PM'ed Uncle Ray already asking about this Gas, Grass Or Ass - Nobody Rides For Free
"UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
21st Apr 2023 2:56pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2654 |
This should give you some ideas as well
http://www.4x4cb.com/public/menu.cfm?Categ...e=Products I use the PSM 1 Mount, using either the short 'rubber' arial when we were green landing as it is below the roof height and does not snag any low branchers as the wound whip versions do. In the open such as Salisbury Plain or when marshalling then i use a 4 foot whip for the greater range. If you know that you will be around lots of people it is best to secure the whip so not to accidently hit anyone. Hope this helps |
21st Apr 2023 3:06pm |
Yes and I’ve edited my post, thanks for pointing that out. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
21st Apr 2023 4:52pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 |
Ray's mounts are definitely up to the job, I have 2 on mine Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
21st Apr 2023 8:32pm |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 161 |
A mag mount won't stick to the Defender's roof.
+1 for Ray's mount: Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
21st Apr 2023 9:01pm |
Just ordered one from Uncle Ray
Wizzardprang, what antenna is that and what’s the approximate length? Gas, Grass Or Ass - Nobody Rides For Free "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
22nd Apr 2023 8:17am |
I don't know whether you remember the aerial on mine when we were in Wales Russell but I bought a SIRIO TURBO 5000 without really looking at the length At a smidge under 2 metres it is rather long but it does get great reception over a distance
Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
22nd Apr 2023 10:23am |
Hi Ian
I have a 1.55m one from 4x4CB that fits the mag mount I bought but was thinking of a short rubber one as we will not be that far from the lead car at any time. I would take both and use accordingly but markb110 mentioned a shorter one was what got me thinking Gas, Grass Or Ass - Nobody Rides For Free "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
22nd Apr 2023 10:32am |
You just reminded me when i took part in the Scorpion Racing Novice Winch Challenge events.
In the first event i caught the springer arial in a low branches and basically straightened it out... I then went for a Sirio thinking that range would be better.....it was until i snapped it green laning. That's when i decided to go for the short rubber arial as they are good for 1.5 miles so perfect in a convoy then swap over to the longer springer when in open areas or the need to be in communication for driving days or when we would marshal at the Army Navigation events. Click image to enlarge Click image to enlarge |
22nd Apr 2023 2:37pm |
markb110, I also straightened out a springer whilst off road green driving and it kinked the roof!
What is the short rubber one you use please? Gas, Grass Or Ass - Nobody Rides For Free "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
22nd Apr 2023 2:46pm |
An SWR meter is also worth getting as they don't cost much and it will help you check the grounding of your set before any damage occurs.
The link below will answer any questions. I don't leave it permanently attached, only to periodically test. i also run a ground wire from the arial mount to the chassis so not to rely on the aluminium body. Hope this helps, and have fun. http://www.4x4cb.com/public/item.cfm?Refer...tegory=439 |
22nd Apr 2023 2:47pm |
