![]() | Home > General & Technical (L663) > CB And Antenna Mount |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2662 ![]() ![]() ![]() |
This could be a good alternative
https://www.thunderpole.co.uk/small-cb-ant...tenna.html https://www.thunderpole.co.uk/mounting-acc...pring.html |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 166 ![]() ![]() |
Sorry reply is a bit late. Mine's a Sirio Omega 27 from Thunderpole. Length just under 1 metre, had to cut about 25mm off for a resaonable SWR IIRC. Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1442 ![]() ![]() ![]() |
I would avoid the THUNDERPOLE 3/8" ANTENNA SPRING, I had one from Thunderpole for my other aerial and it was so rusted after 4 months that I got in touch with Thunderpole. I said it shouldn't rust after just 4 months but according to them that was perfectly acceptable and they refused to replace it. ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 843 ![]() ![]() ![]() |
Would not buy anything from Thunderpole as they are a real bunch of
![]() ![]() ![]() ![]() 4x4CB is who supplied me the antenna, mount and CB recently and a splendid chap Jim is ![]() "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
