Home > Td5 > Mileage display & electric windows switches illuminated
FD7
2006 Defender 90 V8 Petrol ST Auto Chawton White
Hoping somebody can tell me if normal or not (I suspect not...)
But as I'm on the way of completing some jobs for my TD5, I've noticed the electric window switches seem to be illuminated when the vehicle is running but the lights stalks are off.
Similarly the mileage LCD display seems to also be illuminated green under same conditions.
The electric windows were aftermarket to this Landy, but unsure if somethings gone wrong when they were wired up or if it was always like this.
I am sure this is not 'normal' and my other TD5's only did this when the light stalks were switched on.
Post #987397 30th Mar 2023 8:45pm
rallysteve
Mileage display is normal to illuminate with ignition (but rest of speedo will only illuminate with lights).
Window switches shouldnt illuminate with ignition though. Pin 6 on them should be red/orange wire which is the illumination amd fed from the sidelight circuit with all of the other switches.
Post #987404 30th Mar 2023 9:52pm
Some/many/most aftermarket lift switches illuminate when the ignition is on and the lift system is live.
Post #987417 31st Mar 2023 6:59am
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Not normal. According to the wiring diagram the switches have a bulb that is illuminated with the side light circuit on a red/orange wire. Have you checked the supplies with a meter? Are the switches genuine?
Post #987445 31st Mar 2023 12:01pm
Re: Mileage display & electric windows switches illumina
FD7 wrote:
The electric windows were aftermarket to this Landy, but unsure if somethings gone wrong when they were wired up or if it was always like this....
When you say "aftermarket" do you mean someone has retrofitted genuine Landrover parts to recreate a factory installation, or do you mean an aftermarket proprietary lift kit has been fitted?
Without knowing this it is hard to offer useful advice, but if it is the former than I would not expect the lift switches to be illuminated when the ignition is on and if the latter than I probably would.
Post #987453 31st Mar 2023 1:56pm
FD7
Thanks for the replies all Thumbs Up
Yes sorry should have said the invoices are from Masai, so it's a non genuine kit, if I recall an Italian supplier so no original parts used.
The buttons are non-genuine, as it differs to original TD5 slightly (touch / feel / logo etc).
I've not checked anything myself as of yet with regards supplies.
Post #987692 2nd Apr 2023 9:26pm
