Home > Technical > Hazard Switch
nortm
United Kingdom 1986 Defender 90 2.5 n/a Diesel PU Buckingham Blue
Hazard Switch
Hi All,
Re-wiring my 1986 LR90 2.5 NA, I’m struggling with 2 (new) 7 pin hazard switches YUF101490 like these:
Everything works fine when I bypass the switch but not with the switch in the circuit.
On testing, I’m unable to get continuity between pin 8 and 7 in either on or off switch position.
Have I got duff switches or am I missing something?
Many Thanks,
Post #986542 23rd Mar 2023 5:41pm
PaulMc
The Land Rover hazard switch is part number YUF101490
Lucas 30771 (152SA), although similar looking, is not listed as an alternative to YUF101490
So, I would guess that it isn't wired the same.
. Paul.
Post #986550 23rd Mar 2023 6:27pm
nortm
Hi, yes, that is what I have (see post above). Thanks
Post #986552 23rd Mar 2023 6:29pm
PaulMc
Have you got the pin numbers correct Question
This drawing shows the rear of the connector, which corresponds with looking at the rear of the switch -
The wiring should be, as below -
. Paul.
Post #986553 23rd Mar 2023 6:40pm
TexasRover
Can you jump 7 and 8 to see if the switch is faulty? If it all works as it should you know it's a switch issue, no?
Post #986558 23rd Mar 2023 7:20pm
Dinnu
I have this wiring diagram.
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #986566 23rd Mar 2023 7:52pm
Martin
Site Admin
I’ve seen this before, the similar looking switch for a Mini is wired differently inside and doesn’t work!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #986567 23rd Mar 2023 7:55pm
