![]() | Home > Technical > Hazard Switch |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 504 ![]() ![]() ![]() |
The Land Rover hazard switch is part number YUF101490
Lucas 30771 (152SA), although similar looking, is not listed as an alternative to YUF101490 So, I would guess that it isn't wired the same. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' Last edited by PaulMc on 23rd Mar 2023 5:34pm. Edited 1 time in total |
nortm Member Since: 22 Feb 2017 Location: Oxford Posts: 26 ![]() ![]() ![]() |
Hi, yes, that is what I have (see post above). Thanks
Have you got the pin numbers correct
![]() This drawing shows the rear of the connector, which corresponds with looking at the rear of the switch - ![]() The wiring should be, as below - ![]() . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1140 ![]() ![]() ![]() |
Can you jump 7 and 8 to see if the switch is faulty? If it all works as it should you know it's a switch issue, no?
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3479 ![]() ![]() ![]() |
I have this wiring diagram.
![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
I’ve seen this before, the similar looking switch for a Mini is wired differently inside and doesn’t work!
