Home > Td5 > Heated seat cable routing....
2hel
United Kingdom 2003 Defender 90 Td5 CSW Java Black
Anyone have any pictures or able to describe the factory cable routing for heated seats? I'm going to retrofit XS seats into my TD5 and want it to look as 'dactory'as possible.
Thanks all
Post #986048 18th Mar 2023 9:01pm
4RF RDS
Have a look here, not exactly what you are asking for but it will help…
Good luck
https://www.defender2.net/forum/post95241.html 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #986203 20th Mar 2023 4:21pm
disco16
France
Hi,
the first picture of the first page is the factory wiring of heated seats Thumbs Up
Post #986366 21st Mar 2023 8:45pm
2hel
Thanks very helpful as always, i was going to buy an aftermarket kit i think i saw a link on here the other day, i was just wondering the route from the switches to the actual seat bases really? sounds stupid but want to make sure i run them correctly. Laughing
Post #986670 24th Mar 2023 3:01pm
4RF RDS
I ran my universal kit seat heaters wiring down the dash centre hole, behind the fuse box, and under the rubber matting alongside the gearbox tunnel. Then under the seat rail to the seat connector. I have a waterproof disconnect if I ever have to pull the floors up. Hope this helps some.
1967 MGB GT
Post #986681 24th Mar 2023 4:13pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
I ran mine from the centre switches up the window pillar, along the roof above the door then down by the seatbelt to under the cubby box - this is where the relay was to turn the power on so the large wires only ran from battery to the relay then to the seats
I used an Exmoor Trim kit that came with two heat levels, so the defender switches power the two level switches (located on the cubby box)
I don’t actually use the heated base section, just the heated back pad - I find the base too hot
Post #986705 24th Mar 2023 7:51pm
