Home > Td5 > Heated seat cable routing.... |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 952 |
Have a look here, not exactly what you are asking for but it will help…
Good luck https://www.defender2.net/forum/post95241.html 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
20th Mar 2023 4:21pm |
disco16 Member Since: 27 Oct 2022 Location: charente Posts: 3 |
Hi,
the first picture of the first page is the factory wiring of heated seats |
21st Mar 2023 8:45pm |
2hel Member Since: 28 Nov 2022 Location: Essex Posts: 177 |
Thanks very helpful as always, i was going to buy an aftermarket kit i think i saw a link on here the other day, i was just wondering the route from the switches to the actual seat bases really? sounds stupid but want to make sure i run them correctly.
24th Mar 2023 3:01pm |
I ran my universal kit seat heaters wiring down the dash centre hole, behind the fuse box, and under the rubber matting alongside the gearbox tunnel. Then under the seat rail to the seat connector. I have a waterproof disconnect if I ever have to pull the floors up. Hope this helps some.
👇🏻 Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
24th Mar 2023 4:13pm |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 434 |
I ran mine from the centre switches up the window pillar, along the roof above the door then down by the seatbelt to under the cubby box - this is where the relay was to turn the power on so the large wires only ran from battery to the relay then to the seats
I used an Exmoor Trim kit that came with two heat levels, so the defender switches power the two level switches (located on the cubby box) I don’t actually use the heated base section, just the heated back pad - I find the base too hot |
24th Mar 2023 7:51pm |
