Home > Puma (Tdci) > Slight leak on driver's side window rubber of foam seal
nick.bw
United Kingdom 2014 Defender 110 Puma 2.4 XS CSW Santorini Black
Hi all
I have a small leak on the driver's side. It's either the rubber seal or the foam from th bulkhead to the windscreen frame.
How do people go through fixing this. It's a brand new seal around the window. LR genuine.
Thanks
Nick.
Post #985717 16th Mar 2023 9:13am
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
ive seen them done with black silicone sealant ok if you have a steady hand . there was a liquid you could use similar to Thompsons water seal but i cannot remember the name (sorry)
Post #985760 16th Mar 2023 1:43pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Did mine with Captain Tolly’s creeping crack liquid.
Does need a dry warm place to apply it as it takes several hours to dry.
Seemed to work on the foam seam.
Post #985761 16th Mar 2023 1:48pm
andydef90
that's the stuff Thumbs Up
Post #985762 16th Mar 2023 1:52pm
Trundlebus
Yep, I had a leak into the passenger footwell, caused by the foam seal. A couple of doses of capt tolly’s fixed it. Not leaked since and that was 6 or 7 years ago.
Post #986044 18th Mar 2023 8:36pm
