Home > Puma (Tdci) > Slight leak on driver's side window rubber of foam seal |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
ive seen them done with black silicone sealant ok if you have a steady hand . there was a liquid you could use similar to Thompsons water seal but i cannot remember the name (sorry)
16th Mar 2023 1:43pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 730 |
Did mine with Captain Tolly’s creeping crack liquid.
Does need a dry warm place to apply it as it takes several hours to dry. Seemed to work on the foam seam. |
16th Mar 2023 1:48pm |
that's the stuff
16th Mar 2023 1:52pm |
Trundlebus Member Since: 15 Jul 2014 Location: Herts Posts: 99 |
Yep, I had a leak into the passenger footwell, caused by the foam seal. A couple of doses of capt tolly’s fixed it. Not leaked since and that was 6 or 7 years ago.
18th Mar 2023 8:36pm |
