Home > Puma (Tdci) > Needles (presumably from a bearing) in engine oil !!!!
Page 4 of 4 <1234
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
The timing chain never failed on mine.
/Mat
Post #990765 29th Apr 2023 7:05am
Wethering Landy
United Kingdom 2011 Defender 110 Puma 2.4 USW Santorini Black
Hi Matt
Do you have a suggestion on how to remove the sump? I have removed the nuts but it is tricky to access and seems stuck solid.
All going well though.
Here is an image of where I am at.
Post #990925 30th Apr 2023 9:07pm
Purpose-made tools are available for this, such as https://www.amazon.co.uk/Sealey-SEAQF-VS66...B00S6CA93M
Post #990944 30th Apr 2023 11:40pm
Wethering Landy
Excellent - thanks!
Post #990980 1st May 2023 10:37am
Wethering Landy
Dear All
I just wanted to update you all and say a big thank you for all your advice.
I have successfully re-built the engine and after turning over 3 times it started. It sounds like new! which I suppose it should do as most of the things above the cylinder head are new.
Removing the sump was a horrible job and so was getting the alternator back on - but I have learned so much about the Puma engine it makes it all worth it.
So from me to you all - Thank You.
Best wishes
Richard
Post #995212 5th Jun 2023 6:16pm
I'm really pleased to hear that it went well and congratulate you an successfully carrying out a repair which many would hesitate even to attempt.
I am also glad that the forum was able to help. It is a very good forum IMO. Thumbs Up
Post #995224 5th Jun 2023 6:33pm
Page 4 of 4 <1234
