Home > Puma (Tdci) > Needles (presumably from a bearing) in engine oil !!!! |
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 184 |
The timing chain never failed on mine.
/Mat |
29th Apr 2023 6:05am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17383 |
Purpose-made tools are available for this, such as https://www.amazon.co.uk/Sealey-SEAQF-VS66...B00S6CA93M
30th Apr 2023 10:40pm |
Wethering Landy Member Since: 17 Jun 2022 Location: Suffolk Posts: 39 |
Excellent - thanks!
1st May 2023 9:37am |
Dear All
I just wanted to update you all and say a big thank you for all your advice. I have successfully re-built the engine and after turning over 3 times it started. It sounds like new! which I suppose it should do as most of the things above the cylinder head are new. Removing the sump was a horrible job and so was getting the alternator back on - but I have learned so much about the Puma engine it makes it all worth it. So from me to you all - Thank You. Best wishes Richard Click image to enlarge |
5th Jun 2023 5:16pm |
I'm really pleased to hear that it went well and congratulate you an successfully carrying out a repair which many would hesitate even to attempt.
I am also glad that the forum was able to help. It is a very good forum IMO. |
5th Jun 2023 5:33pm |
