Home > In Car Electronics > Hands free microphone problem |
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 333 |
Still not turning on this morning and so I have disconnected the battery and I’ll have another look in half an hour or so.
7th Mar 2023 9:11am |
Reconnecting the battery forced the unit to reset as expected and I had to set up the time/date and language etc.
The microphone still doesn’t work and I am repeating the firmware update (it takes a while) and if that doesn’t work I’ll try the new mike. |
7th Mar 2023 10:01am |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 316 |
My Kenwood DMX 5020DABS went to sleep during a firmware upgrade a few weeks ago, the unit was unresponsive. The advice from Kenwood was to disconnect the vehicle battery, download the firnware update to a different USB (or reformat the one you have), reconnect the USB to the unit, reconnect battery, see if download recommences. Thankfully this worked and the unit is fine.
You must make sure you upgrade the two firmware files in the correct order! |
7th Mar 2023 11:35am |
I finally found time (when it stopped snowing) to try the new microphone and it works! I now need to route the cable through the dash, along the windscreen pillar and under the headlining!
Thanks to everyone for the suggestions. |
10th Mar 2023 1:38pm |
matchap801 Member Since: 05 Aug 2021 Location: Somerset Posts: 120 |
Excellent. Glad it all worked out in the end 🙂 2009 Defender 90 CSW 2.4 TDCI.
Ex Army Mechanic still living the dream. |
10th Mar 2023 4:50pm |
