Home > In Car Electronics > Hands free microphone problem
Page 2 of 2 <12
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
Still not turning on this morning and so I have disconnected the battery and I’ll have another look in half an hour or so.
Post #984666 7th Mar 2023 9:11am
SteveK
Reconnecting the battery forced the unit to reset as expected and I had to set up the time/date and language etc.
The microphone still doesn’t work and I am repeating the firmware update (it takes a while) and if that doesn’t work I’ll try the new mike.
Post #984677 7th Mar 2023 10:01am
matchap801
United Kingdom 2009 Defender 90 Puma 2.4 CSW Zermatt Silver
Well done. Shocking bit of firmware from the manufacturer. 2009 Defender 90 CSW 2.4 TDCI.
Ex Army Mechanic still living the dream.
Post #984678 7th Mar 2023 10:05am
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
My Kenwood DMX 5020DABS went to sleep during a firmware upgrade a few weeks ago, the unit was unresponsive. The advice from Kenwood was to disconnect the vehicle battery, download the firnware update to a different USB (or reformat the one you have), reconnect the USB to the unit, reconnect battery, see if download recommences. Thankfully this worked and the unit is fine.
You must make sure you upgrade the two firmware files in the correct order!
Post #984688 7th Mar 2023 11:35am
SteveK
I finally found time (when it stopped snowing) to try the new microphone and it works! I now need to route the cable through the dash, along the windscreen pillar and under the headlining!
Thanks to everyone for the suggestions.
Post #985034 10th Mar 2023 1:38pm
matchap801
Excellent. Glad it all worked out in the end 🙂 2009 Defender 90 CSW 2.4 TDCI.
Post #985061 10th Mar 2023 4:50pm
Page 2 of 2 <12
