![]() | Home > General & Technical (L663) > Link Rods |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3071 ![]() ![]() |
Can you contact the previous owner? They might still have the original parts.
Defenderattacker Member Since: 16 Feb 2023 Location: Dorset Posts: 12 ![]() ![]() |
Already asked. As an alternative does anyone know how long the 2” lift rods are? Then I can work out what the originals were. Thanks.
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 156 ![]() ![]() |
The Allmakes Terrafirma adjustable lift rods apparently go from standard height to a 2" lift. These are listed for a D3&4, but if the L663 rods are different, the seller will be able to help. (I not so familiar with them as I have never used rods due to the IIDTool having this capability electronically
![]() ![]() ![]() Click image to enlarge ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s, 2 FL1s and a L663 on the way |
Yes they are different. Anyone?
Was hoping to make and fit some replacements over the weekend.
Anyone?
MattF Member Since: 28 Oct 2022 Location: Norwalk CT Posts: 32 ![]() ![]() |
If it would help I have a set of 1" lift rods from Lucky8 I can measure
Yes please
1 inch lift links
Long link = 5.5 inches Short link = 3.5 inches ![]() Click image to enlarge ![]() Click image to enlarge |
Thanks very much
Centre of each hole in mm would be better, look like they’re actually a bit over your measurements. If it’s anything like a discovery 3 1mm rod length equates to 5mm difference in car height Exact measurements would be good.
That's the camera angle - they are not over. I'll get mm measurements for you
Hope these help -
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Perfect thank you
